Hello Andrey
You said that you measured this voltage drop to around 8V at the generator relay (68)
You measured this drop all the time or only if you press the starter knob?
As you changed your system voltage from 24 to 12 V you can't use the old generator (70), generator relay (68) and genarator regulator (69)
Did you also measured the voltage drop during starting
1. direct at the battery?
2. direct at the starter?
As you have changed the starter from 24V to 12V and the new starter has the same power as before than the current from battery is doubled as before. So on all old lines the voltage drop is also doubled. For this a 44 AH Battery is really to small.
To make it correct you have to change all main wiring to a bigger size to minimize the lost.
Which seal on "down pipe" you mean (photo or article no.)
