Hello All,
I made some tests tonight...seems to be OK.
Engine starts a bit slower compared with the carb...maybe one rotation more, but there is no annoying play with the choke and throttle., stable idle .....welcome to the late 80-ties
On 2-nd low gear I manage to go over some curbs on my street on idle - so idle is pretty stable. There is a small problem, as ECU take signal for RPM's from Verteiler and originally receives 2 pulses per crank rotation, but now there is 3. So engine probably idles at 750 rpm, but the ECU 'see' 1000rpm.
Which is ok, but the alternator makes just 12,5-12,8 Volts at this engine speed, so no normal charge. If I able to fight my laziness I'll make an smaller pulley for alternator.
Next step is to connect Lambda sensor. I bought a new one - 1 wire proper for this ECU , but probably for the test I'll connect Wideband sensor... I have some old PLX controller (left over for some old project) with display and 0-1V output.
If there is some normal AFR readings....Mono Jetronic will stay in the Unimog.
Please comment!
